1950 DeVille License plate brackets
Started by Christopher Smith, September 09, 2009, 08:24:54 PM
Christopher Smith
Need front and rear license plate brackets for a 50 Series 62 coupe.  Any non-caddy replacements?  I'm not too concerned about exact original, just want something that bolts into the same holes in the bumpers.
Also, know anyone that reproduces the rear license lamp lense?  Thanks.
1989 Eldorado Biarritz
1992 Sedan Deville
1950 Series 62 Coupe
Former:
2000 Deville
2012 SRX Premium
Russ Hobden #1235
I have two parts for the front bumper license plate holder which were on a 1950 series 62 sedan.  I assume it is the same for a coupe.  It is missing the part that holds the plate at the top.  Also missing are all the nuts and bolts.  In other words, all I have is the main bracket that bolts to the top of the bumper and the arm that the bottom of the license plate bolts to.  What I have are in very good condition with no rust but will need to be painted is all.  If you can use them, email me.  Russell@centurytel.net.
