Polyurethane Strut Arm Bushings
Started by John Baker, January 24, 2009, 07:28:54 AM
John Baker
I need to replace the strut arm bushings on my 1967 Calais. I have been unable to find polyurethane bushings for this application. Any suggestions on a source for this item would be appreciated.
John Baker
Dave Shepherd
John,
On your car I think you will find that there is very little advantage to using anything but standard (good Manufacturer) strut arm bushings.
Greg
John Baker
Thanks Dave and Greg,
Will do. I ended up with MOOG bushings, hope that they will last for a while.
John Baker
John,
If they are put on correctly, meaning front piece to the front and not backwards, and if the strut rood adjustment is made carefully, mening DONT TWIST THE STRUT ROD BUSHINGS. you should get years out of them.
Greg
Quote from: "Cadillac Kid"  Greg Surfas 15364 on January 24, 2009, 06:29:53 PMput on correctly, meaning front piece to the front and not backwards
I assume these are like many manufactures were in the 60's.  Threaded rod, nut, cupped washer (part of kit), rubber, frame of car, rubber, cup washer, nut.   I replaced them on my ford recently and got rubber Moogs.  I just happened to notice the instructions in the box (who reads directions?)  with the new parts instructed me to orient the washers the opposite way than the original ones were.   I did as instructed and it seems to be working fine.   I have since run into great debate on which was correct.   Is this the same issue with the cad ones?   IIRC on my ford the rubber would only fit one way because the two pieces had to fit into each other as they went through the frame.
