63 Series 62 Body Tag Decode Help
Started by Pat, May 11, 2005, 01:47:43 PM
Pat
Style 63 -6239
Trim 33
Paint 22
TOP ACC EXYK
Rob Gerace #16100
Pat,
  Heres some of it.  Someone else will have to help with a couple of the things.
By the way, I didnt see it in your post, but most plates have a body number also.  The body numbers went in the order of production for each model.  For example, if you had an Eldorado with a body number of 547, your car would be the 547th Eldorado made that year.
Heres what I know.
63-6239:   The 63 is for 1963, and the 6239 is the style code for a 4-door 4-window sedan.
Trim:   33 is your trim code.  It corresponds to the material and color of the interior.  Someone who has the salesman data books should be able to tell you what color/material goes with code 33
Paint:  22 is "Benton Blue Poly"
Top:  If the car came with a vinyl or convertible top, this code would tell what color it is.
ACC:  E, X, Y, and K are codes for the options that your car was ordered with.  I dont know which letter goes with which option, so someone else will have to cover that one.
I hope that helps you at least a little bit.
Rob
Pat
Thanks Rob.
Open items:
Quote from: Rob Gerace #16100Pat,
Heres what I know.
Rob
Pat
Quote from: PatThanks Rob.
Open items:
Lucas F. CLC #15674
Open items:
Trim 33 = Light Blue Caravelle Cloth with matching light blue bolsters, light blue on lower dash, dark blue instrument panel top, medium blue carpets.
ACC:  E = Safety Ray Glass X = Power windows Y = Power seats K = Air conditioning
Lucas F. CLC #15674
1963 Series 62 Convertible
Pat
