Will 77 DeVille radio fit "77 Seville
Started by Rob Bruining, May 14, 2005, 10:41:01 PM
Rob Bruining
I need to replace the radio in my 77 Seville. I have located a radio out of a 77 DeVille. Will it fit? Will I have any to make any modification to the wiring? Thanks.   Rob
Doug Houston
Checked the 1977 Delco manual and the Eldorado and Seville radios show as the same, but the DeVille (and probably Fleetwood) radios have the two big plastic "wings" mounting the set.
One thing you might investigate though, is if the front faces on the Eldo-Seville set can be swapped with the Deville set. I havent  both models here, but its a good chance you could do it.
