Opera seat support bracket for '37 LaSalle
Started by 1937 LaSalle coupe, November 30, 2015, 09:05:42 AM
1937 LaSalle coupe
Hello everyone. I need 2 opera seat support brackets for my '37 LaSalle coupe. These brackets fasten to the bottom of the seat and fold down when in use. Probably '37 and '38 LaSalle and Cadillac would share the same brackets. Thanks... John C. Lehman ... CLC# 26365....
1937 LaSalle coupe
Hello everyone. If no one has these brackets, could someone post a nice close-up pic and give some measurements ? Thanks... John C. Lehman... CLC # 26365...
Jeff Hansen
John,
Contact CLC member Jack Hotz in Haddonfield, NJ.  Jack is president of the club's LaSalle chapter and is restoring a '37 LaSalle coupe.  Hopefully, he can help you.  Contact info is in your membership directory.
HTH,
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
Tom Beaver
John,
There are three pieces to the support brackets, the support lever, a latching mechanism and a cover plate.  Do you have any of these pieces?  If you can't find any information I could get you some dimensions for the support lever and cover plate from my car.  The latching mechanism, however, is  buried under the upholstery.  I have a couple of pictures that would give you some idea of what it looks like.  Let me know if I could help.
Tom Beaver
1937 LaSalle coupe
Hi Tom. I don't have anything. So any dimensions and photos would greatly be appreciated... Thanks... John C. Lehman... CLC # 26365...
Tom Beaver
John,
Give me a day and I will send you some pictures and dimensions in a PM.  My car is a 38 but I am pretty sure those parts are the same as the 37.
Tom Beaver
Tom Beaver
John,  did you ever get the PM I sent you?
Tom Beaver
