1934 Cadillac Inside Rear View Mirror Wanted. Are other years the same?
Started by 34lasalleclubsedan, April 14, 2013, 02:10:34 PM
34lasalleclubsedan
Hi Guys, I am in need of a inside rear view mirror for a 1934 Cadillac Closed car. I really don't need the bracket, just the mirror itself. Some of you Cadillac guru's may know if these are the same for other year Caddy's and models, such as V8 V12 V16??? That info would be of help in my search. Thanks so much , Jim
Jim Fredrick
Warren Rauch #4286
The brackets only fit a couple of body styles. The parts book also  lists #1096343 , glass and frame assembly for rear view mirror with ball swivel. It fits series 350 ,355D,370D,452D and 36-90 ,37-90. ( that's  all 34-35 Cadillac /Lasalle and 36-37 v16)        If the glass can be removed from the frame, you will probably be faster to fix it. Most glass shops will cut you new mirror ,if you only need that. You might also check into having it resilvered.Warren
Warren Rauch #4286
Correction; The 1935 LaSalles were series 35-50 ,so they used a different mirror. Warren
