What does the correct 1959 convertible top switch look like?
Started by Sean Roe, February 05, 2015, 11:33:04 PM
Sean Roe
Hi All,
Does someone have a picture of what the correct top switch looks like? I'm assuming it goes in the hole on the dash, above where someone put a toggle switch on the car we have.
I'd like to put the correct one in.
Thanks in advance.
Sean
Coupe Deville
This one isn't from my 59 but it looks like this...
Sean Roe
Ah, looks like a regular window switch.
I'll see what I can find.
Thank you!
59-in-pieces
Sean,
I can only speak to 59 Cad Eldo Convrts.
The switch bezzle is square - not a rectangle.
Here is a pic of the switch.
Have fun,
Steve B
S. Butcher
Quentin Hall
. . . But the pins on the back are stacked vertically not L pattern like the window switches tho.
57 and 58 window switches are the style you need for 59 top.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
