oil leak, coolant leak, belts..<sigh>
Started by Cape Cod Fleetwood, May 30, 2018, 01:37:45 AM
Quote from: Cape Cod Fleetwood
I mentioned welding it, he said to get another one.
The car came with gauges, that didn't work. And 4 live wires behind the
gauges about to set the firewall insulation on fire... Wires were twisted
together and wrapped in duct tape. <sigh>   \m/   Laurie
It always takes me weeks if not months to get a car up to standard.  Guess
some wiring work is in order, the only way duct tape is involved, is as
possibly an outer wrap before applying a clamp.  good luck, Bruce Roe
Cape Cod Fleetwood
Quote from: bcroe on June 06, 2018, 01:31:06 AM
Indeed Bruce!
I'm pretty happy with the way things are going. Doing all the important engine stuff and little
bit of fluff. I want to buy all the 'pretty' parts, Scott wants all the important parts, LOL!
REALLY looking forward to the front brake job. When that is completed and working properly THEN
I'll have him remove the failed EB rear cables and send them off to InLineTube for replacement.
I've broken this project down to 3 groups in order of importance:
1) engine/mechanicals
2) body
3) interior
The speed of which this is accomplished is determined by my expendable cash.
\m/
Lauriee
The Past -
1996 Deville Concours
1981 Coupe De Ville (8-6-4)
1976 Sedan De Ville
1975 Sedan De Ville
Highwayman68
The crack in the steering pump bracket could be the result from the misaligned belts causing a vibration. This is the first time I have ever heard of anyone having a crack in this bracket for any year.
A used one should work fine from a car that someone didn't mess up the pulleys on LOL.
Cape Cod Fleetwood
Quote from: Highwayman68 on June 06, 2018, 08:26:27 AM
That makes sense Mark. Its only aluminum.
\m/
Laurie
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
cadillacmike68
I'm almost certain that I have a spare PS pump bracket.  Not cracked.
I've had cracked ones in the past and ones where the top edge wasn't even there anymore!
"Cadillac" Mike
Cape Cod Fleetwood
Quote from: cadillacmike68 on June 06, 2018, 09:59:12 PM
1) Wanna sell it? LOL!
2) And it still held good tension on the belts? Mine is cracked vertically.
\m/
Laurie
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
cadillacmike68
Quote from: Cape Cod Fleetwood on June 06, 2018, 11:16:13 PM
\m/
Laurie
Maybe.
The PS pump has two sliding anchor points, not just one, plus it has the fixed pivot point.
"Cadillac" Mike
Cape Cod Fleetwood
Quote from: cadillacmike68 on June 06, 2018, 11:43:53 PM
Maybe.
I saw that today when I was CAREFULLY spray painting the freshly installed AC condenser.
Those engineers knew what they were doing, they built in a Plan B and Plan C. Prolly why Scott
said look for another one but not in panic mode.
Does this happen to you guys... you're 3 days away from a show and tinkering under the hood. You see something that's "dirty" so you get out the rag sprayed with WD40 and start wiping. The rag hits something you didn't intend to wipe off but now you're compelled to since "that" has a clean spot now. 2 hours later after only intending to wipe off the air intake area you've ragged off the whole flippin' engine...
Car therapy.
\m/
Laurie
The Past -
1976 Sedan De Ville
1975 Sedan De Ville
"Does this happen to you guys..."
Only about 90% of the time.  Same reason that so many of us have started out to fix one problem only to end up a few years later having restored the whole car!   ;D  ;D  ;D
