WTB '54 distributor
Started by timer2, August 01, 2021, 06:40:10 PM
timer2
Looking for a good used distributor from a 1954 331cid with distributor # 1110844. '55 might work also but I don't know the tag number. Thanks, T. Irvin
Poncholover
'55 fits. You can always use your springs & Vac advance unit.. '56 should also be very similar.
Flattie Caddy
timer2
Thanks. I have a distributor from a '56 in the car and would like to get closer to original. The 56 dizzy has a bad vacuum advance chamber and I've been told it's a one year only part. Something rebuildable would be fine also. T. Irvin
denniscaddy
Hi,
I have one.  844.  Has vacuum advance, plate and points.  Looks good.
Email  dennis@caddyparts.com
Thanks, Dennis
CLC 3676
1941 Fleetwood 60S
2017 CT6
timer2
