Status of poor response time issue
Started by Jeff Hansen, #4225, July 20, 2005, 02:44:28 PM
Jeff Hansen, #4225
All,
Our web hosting firm will be moving our website to a different physical server within the next 24 - 48 hours.  Nothing about our setup will change other than the fact we will be running on a different computer.  URLs, etc. will remain unchanged.
I also will be removing older posts from the Forum to trim its size.
It is hoped that these two steps will return response times to an acceptable level.
Again, I thank you for your patience during the diagnosis and resolution of this problem.
Jeff
Jeff Hansen, #4225
All,
We are now running on a different computer and I have pruned about seven months worth of old posts from the Forum.  This should return response times to an acceptable level.
If response times continue to be acceptable, there will be a surprise coming to the website right after the Grand National.
Thanks again, everyone, for your patience!!
Jeff
Michael Stamps 19507
Seems better here tonight.
Stampie
PS - Surprises keep life fun.
Rusty Shepherd CLC 6397
Im finding it to work perfectly...thanks again for all your efforts, Jeff.
