Small block chevy in '37 LaSalle
Started by bigbeckley@outlook.com, May 01, 2021, 05:50:25 PM
Hello everyone... For right now I am putting a 327 Chevy engine in my '37 LaSalle... Just wondering should I   keep the shutter thermostat system on the radiator or go with the thermostat in the small block? I know the flathead Cadillacs never developed that much radiator pressure. Anyone else do a small block Chevy into a early Cadillac LaSalle... I am keeping the LaSalle 3 speed on the floor... Thanks for any replies... John C. Lehman... CLC #26365...
G'day John,
Could you go with both?
But I do know that the Chev engines were designed to use a pressure system to increase the coolant boiling point, so you might need to convert your radiator to one that will take pressure so I am wondering if the original thermostat will take the extra pressure.
Thanks Bruce... I know Cadillacs and LaSalles had huge radiators. A lot more volume of coolant. The system pressure is regulated by the radiator cap... I think I have an original rad. cap... I think they were rated a 4 lbs. Will have to experiment around by keeping the shutters open for now... John C. Lehman ... CLC # 26365...
Jamurray
They may have had huge radiators, but very few flathead owners brag about how cool they run. The issue may have been the engine design and not the radiator, but I would ditch the original vane actuating thermostat and use what came with the 327.
Assuming it comes to pass, a stretch perhaps, when I get to heaven I'm going find Zora Arkus-Duntov and thank him for his Chevrolet Small Block.
