Wanted: '47 Sedanette left door manual window regulator
Started by Mayoroftaylors, July 20, 2016, 02:00:03 AM
Mayoroftaylors
Steve Passmore
I presume your talking about the main wind up window?   Most of these regulators were very similar. If your prepared to do a little work you could adapt one from another car.  The main difference with them are the actuating arms and their position on the toothed cam.   I have drilled out the welds and removed the arms and welded my own back on a few times over the years to get a new regulator.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
harry s
The Master Parts Book lists a lot of different numbers for that part. Check with Steve Cooley in Fla. He specializes in that era car. 352-382-2271 or Larry Lawrence in Texas 903-563-0135. Good Luck,     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Barry M Wheeler #2189
#3
Since there were two sedanettes in 1947, it would help a lot to know which car you need it for. The Series 61 used the same regulator as Buick Special, and the larger (not 98) Olds and Pontiac models from 1941-1948.  The Series 62 used the same as 1942-48 Buick Super/Roadmaster and the Olds 98. Obviously, you are going to be able to find a lot more Buick/Olds/Pontiac stuff than Cadillac. And probably cheaper. Bob's Buick might be a good place to start.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Mayoroftaylors
Oops... Forgot about the series. It's a 62.
Thanks for the info
