39 LaSalleShock Absorber Fluid
Started by D.J. Bray, September 01, 2005, 01:53:23 PM
D.J. Bray
What is the fluid used in the shocks for a 39 LaSalle.  Is it regular hydraulic fluid or a special fluid?
Thanks.
Mark
Just filled up the knee action shocks on my car with Motorcycle Fork Oil.  I forget who recommended it to me but it seems to work good.
Doug Houston
Ive always used hydraulic jack oil. Good stuff, too.
D. J. Bray
Robert Meyers
Have a very old can of jack oil. On the label, it witten "Hydraulic Jack oil (and knee action shock absorber)"
Ivan Zanatta
Would these units be similar to the Chev/Pontiac units of the same era? They have an odd arrangement where the coil spring and shock absorber is in one unit (on my Chev, anyhow), and the whole lot pivots on the king pins on the end of a solid-mounted axle. I thought these were exclusively chev/ponty but Lasalle being GM may be the same. Ive been looking for a suitable fluid too.
Ivan
