WTB rear axle seals for 1937 Cadillac series 75.
Started by boothandco, December 05, 2015, 05:01:00 PM
boothandco
Looking for a source or cross reference for rear axle seals for a 1937 caddy series 75.
Chad Booth
1937 Series 75
1999 Fleetwood Limited
1976 GMC Motorhome
Previous:
1989 Sixty Special
Reformed Lincoln 4 door convertible owner.
boothandco@sisna.com
harry s
Chad, i replaced the axle seals on my '37 75 series a number of years ago and can't find the part number right off hand. They were not hard to cross from the number that came out. In case you haven't taken it apart yet the seals are located inboard inside the housing which means the rear pumpkin has to come out. There is a ventilating system that vents the pressure  through the inner housing at the top and then out of the outer housing at the bottom next to the drain plug. In a lot of cases either the system gets plugged up and causes the seals to leak. Maybe someone will have the part number for the seals. Good Luck,     Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
mribbich
National seal number 50167  try Olcar bearings 1-910-693-3324
Marv.
boothandco
Chad Booth
1937 Series 75
1976 GMC Motorhome
Previous:
1989 Sixty Special
TonyZappone #2624
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
boothandco
Chad Booth
1937 Series 75
1976 GMC Motorhome
Previous:
1989 Sixty Special
