1948 Series 61 Restoration Almost Completed
Started by Rod Dahlgren #19496, December 13, 2017, 04:37:47 PM
Rod Dahlgren #19496
OK-- Here I go with the 48 photo report. This is set one. The car had been parked out in a field since the engine blew up. Taking the engine apart, there were a couple rats in the oil pan that had entered through the oil fill tube. That should give you an idea how the rest of the car looked. Finding good restorable pieces for a 1948 has  been quite a task. The authenticity manual and the Fisher Body were a must along each step of the way. And then also were the guys that helped with details. Ed Gunther has been a big help! That color Amherst Blue was important to get right. Not too much metallic like I see on some cars. And the Di-Noc Leather Grain interior trim was a slow difficult process.
OK-- Here is set 1 -- More to follow.
Did You Drive Your Cadillac Today?
Rod Dahlgren #19496
Set #2 -- Hope I am doing this the right way
Rod Dahlgren #19496
Well--- I just lost the last set---  So here it is again in a short version
harry s
Rod, Looks great and almost finished. Keep the pictures coming. Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
