help with identification and location of parts
Started by chris92026, January 10, 2018, 12:41:09 PM
chris92026
can anyone tell me what is it for or where he goes
thank you
59 Cadillac Deville
C.Perrin
The unshielded slide-on terminals indicate those wires are grounds.  The white plastic piece to the right of the picture looks to be a broken in-line fuse holder, so we might be talking add-on accessory, factory or aftermarket.  The small wire with the yellow connector should have that yellow connector replaced with an 18-22 red connector --- just asking for a broken wire there.  Sorry I can't be any more help than that.
Dan LeBlanc
If I had to make an educated guess - generator to voltage regulator harness.  This is one of the few locations where an in-line fuse was used.  The inline fuse was for the generator light in the dash.
Dan LeBlanc
Plus, the terminals definitely look like the ones used on a Generator and Voltage Regulator.
If this wiring is in a car that has an Alternator replacing the Generator, then these wires would have been removed, and the Alternator wired up in the normal way when bypassing the Voltage Regulator.
chris92026
thank you
will look at the diagram
still, a generator but everything has been a disconnect by the previous owner so more question to come  ;D
C.Perrin
