Vacuum fitting for 76 Eldo
Started by mtravinski, July 04, 2014, 09:22:48 PM
mtravinski
Does anyone know where someone may be able to obtain the vacuum "Y" fitting on a 1976 Eldorado 500? Any and all help will be greatly appreciated.
mtravinski
Where is this part located?  What part of the system is it for?   Are you looking for an original 'correct' part?  Or just something to make it work?  Larger parts stores will have various vacuum fittings on display in the Dorman Help! line,  betting you can find something that will work there.
mtravinski
It's the "Y" fitting that comes off of port A on the carburaetor and the primary vacuum break unit of the motor. It shows pretty clearly on the vacuum routing diagram of the 1976 shop manual.
A google search for this item brings up the Dorman catalog mentioning "Y" fittings but an actual review of the catalog produces no results.
Unfortunately the size of the drawing I was trying to attach will not be accepted by this site. I will keep working on the format and try to post as soon as I am able to.
Thanx,
mtravinski
This is on the front of the carb and has 2 very short pieces of hose on it?
Are you just looking for something that will work or an actual show quality correct part?
mtravinski
Yes! That is the piece. I would very much like to have the original piece but will settle for one that does the job until I can find the correct one.
Thanx,
mtravinski
Any parts store should be able to get these, they may have to cross it to their brand, like Napa calls the Doorman stuff Balkamp.
Look up Doorman part numbers:
47325  1/8x 1/8x 1/8  T
47350  1/8x 1/8x 1/8  Y
They have other sizes but I believe 1/8 is correct.
