exhaust manifold gaskets, 346 flathead
Started by Rhino 21150, January 28, 2007, 09:25:07 PM
Rhino 21150
On the old flatheads there are three pieces of exhaust manifold bolted to each other. Are there supposed to be donuts between the sections of casting? Also, should there be a donut between the manifold and the headpipe? Or do these use flat fiber gaskets (asbestos or substitute)?
baxter culver #17184
There are two flat gaskets for the crossover pipe and a flat gasket for the exhaust pipe/manifold interface.  The two exhaust manifolds use a longer strip gasket with several holes.  All are fiber or asbestos-type gaskets.  They are available from Coopers as a set.
Barry M. Wheeler #2189
Also available from Terrill Machine. Adv. in HMN.
