1963 Eldorado Wood Veneer
Started by justiny, May 18, 2022, 02:20:07 PM
justiny
Has anyone removed the wood veneer in either a 63 Eldorado or Fleetwood?  The veneer appears to be good condition, though the glue is old and the veneer is starting to lift.  My hope is that I can clean it up and re-glue the existing material.  Any tips or help on this would be greatly appreciated!!!
Thanks!
Justin
2manycars
Hey Justiin
Check this thread in the restoration section. Carl is doing veneers on his 61 Fleetwood. He might have tips for you...
https://forums.cadillaclasalleclub.org/index.php?topic=158620.380
1964 Coupe de Ville
My Current Projects:
1957 Ford Thunderbird
1967 Chevrolet Camaro RS Convertible
My Special One:
2001 Chevrolet Corvette Convertible (bought it new)
Clewisiii
There is a possibility.  But before you start ask yourself how far you are willing to go.  .
For 1961 the veneers are all symmetrical and coated on both sides. So the backs looked great and I thought I could just clean the glue and maybe one coat of clear and reuse them.
But just because most of the glue has failed. Does not mean all has failed.  Three came off completely clean, then one corner broke.  So I am in it completely. The original material for me was .03 inch thick.
justiny
Quote from: Clewisiii on May 22, 2022, 07:00:38 AMThere is a possibility.  But before you start ask yourself how far you are willing to go.  .
Thank you!  I followed some of your posts on the veneer work you're doing.  Looks excellent. Most of my veneer is in nice shape, with the exception of a few spots where the lacquer has lifted.  I'm trying to determine if it's possible to "re-glue" the areas that have lifted rather than turning it into a major ordeal. Any thoughts?? Thanks again!
justiny
Quote from: 2manycars on May 21, 2022, 09:58:01 PMHey Justiin
Thank you!!!
Clewisiii
It would be situational.  But I think it would be hard to reglue consistently without first removing it.  But depending on your shape and area it may be possible.  But the question is what kind of glue are you using.   I have a sheet stock PSA adhesive on mine.  Most upholstery people will use Weldwood high heat landau top adhesive.  But I don't know if that is right over chrome.
