am getting to the end of the body prep on my 57 eldorado and need to remove the trunklid , question is , is there a set way to remove ? or do i need to undo the torsion bars that run across the back seat area first ? i dont want to undo the bolts and have the hinges spring back into my rear screen ! :o
will be removing the doors as well , is there an easy way to do it ? .
thanks in advance ... paul .
thanks for that, all done and ready for final prep ... ;)
