I AM IN THE PROCESS OF DISMANTLING MY GRILL AND SOME OTHER CHROME PIECES. I WOULD LIKE TO KNOW HOW THE PLUG DISCONNECTS FROM THE REAR OF THE HOUSING OF THE FRONT TURN SIGNALS.I WOULD APPRECIATE ANY ADVICE.THANKS CHARLIE 1949 SERIES 62
Hmm, and the car is?
If I understand well, Charlie has a 1949 Serie 62.
THANKS ROGER.I FIGURED IT OUT. CHARLIE
As I remember it the wires stay in the housing and continue up to the fender blocks on each side where there is a block with screws in it mounted to the fender paneland you loosen the screws and draw the wires back thru the fender to the housing and remove the housing with wires still attached
Herman
