What's the best way to polish chrome? What do you use? Thanks.
The least abrasive product as possible. I still prefer 0000 Steel Wool with nothing more. Use it on chrome, glass, etc. Also Rolite, Simi-chrome, Wenol, etc. all good cleaners. Also Check out Eagle One, a Wadding compound in a small silver can. Leaves zero residue and is about the quickest, most efficient way to clean chrome. Been using it on bikes forever. Does a nice job of getting into all the nooks and crannies and you don't have to worry about leaving anything visible behind. ;) Good luck,
Bobby
Simichrome with a microfiber cloth. Steel wool on chrome just sounds bad so I've never tried it. NevrDull is another choice that has worked for me.
Quote from: 7gen on January 21, 2017, 11:32:03 AM
0000 steel wool won't hurt your Chrome, Stainless, Glass, etc. Less abrasive than most polishes you use, and no mess. Old body shop trick to remove overspray from Glass/Chrome. Try it......
Bobby
Thanks for the tip!!
I use the 0000 steel wool on older chrome and stainless.
On new chrome and polished stainless I use a good quality foaming glass cleaner and a micro fiber and then use a carnuba wax.
I found some stuff at a car show called Bimbo's Extreme metal polish.
I used that on some 0000 steel wool to clean up some dull and oxidized bumpers on a 65 Vette and got some amazing results.
I have found bronze wool (fine) works great. It is just a little softer than steel wool and doesn't shed. You can use it plain or with polish. Harry
Autosol cream. Nothing better IMO
Quote from: harry s on January 21, 2017, 07:09:36 PM
Harry,
Is that a Southern Thing? ;D I've never seen "Bronze" Steel wool before. Only in my Wife's kitchen sink, but that stuff will scrape paint off :o
Bobby
Bobby, Here's a link for the bronze wool pads. They are very fine and soft: https://www.amazon.com/s/?ie=UTF8&keywords=bronze+wool+pad&tag=mh0b-20&index=aps&hvadid=3527279624&hvqmt=e&hvbmt=be&hvdev=c&ref=pd_sl_1oftwqmup_e
They are used in a lot of marine applications. I tried getting them at the local Ace Hardware and was told they no longer stocked them as some were useing them for filtering the MJ. Harry
I need to get some of that bronze wool.
The other benefit of using it is that if the little shavings get down in between things it won't rust if it gets wet.
Also softer is better in some instances.
But for cleaning up old chrome that is oxidized the steel wool with any kind of compound or polish works great.
Once it's rechromed and looking good I don't see any need to touch it with an abrasive or anything but a mild cleaner and wax. If you wouldn't use it on your paint, don't use it on new chrome.
I like Mother's chrome polish.
As I recall all polish even chrome polish have some abrasives included and remove minute amounts of paint and chrome during the polishing process. Getting it clean and waxing it is the most productive way to maintain the finish. For removing oxidation and chrome deterioration I use the least abrasive product that will do the job and then keep the surface in good shape with wax.
If you want to POLISH it, then use a cotton buffing wheel with or without rouge or fine compound. Have to know what you're doing or you'll haze it.
If you want to CLEAN it/bring it up to shine, chrome "polish" and whatever applicator you need to bring up the finish and remove the crud. If you need metal wool, it's pretty bad. Usually a cotton cloth will do. I save old towels, Tshirts, etc. I wouldn't go below 0000, you can scratch. I even use OOOO on glass to remove the water spots, with the mothers water spot remover.
I used to use the old tan simoniz chrome polish but I don't think it's around anymore, so the last good stuff I got and still use is turtle wax chrome polish (white cream)green plastic bottle. I tried some Dupont stuff after my simoniz ran out and it didn't work that good.
We used everything from coca cola, cleanser, brillo pads, to wadded up aluminim foil back in the day.
Always give it a good coat of wax after cleaning or polishing as the nickel is what dulls due to oxidation. The protective chrome top layer is not that good unless you have really high level show chrome. Once it rusts through, then the iron oxide bleeds through and you have to take that all off to get any shine. Even bad chrome will look pretty good, if you know how.
Mothers has polymers in it to protect the chrome after you polish - no need to wax afterwards.
Quote from: Bobby B on January 21, 2017, 01:23:59 PM
Bobby
0000 Steel wool is the best way to do it. Great info on Eagle 1
Hello, just wondering if anyone has had success polishing chrome in this condition (see photos)? I have tried 0000 steel wool, mothers polish, and Autosol but no luck yet. Thanks in advance!
Quote from: Jose1941 on February 10, 2023, 03:30:41 PMHello, just wondering if anyone has had success polishing chrome in this condition (see photos)? I have tried 0000 steel wool, mothers polish, and Autosol but no luck yet. Thanks in advance!
Nice 1958 fleetwood sixty special!
Sometimes the chrome is just too far gone,
