Does anyone know where to find re-built a ECM or ECU? Bendix has a part number of 1614448 and Im having a difficult time with this search. I have a 78 Seville.
Quote from: Clyde JasonDoes anyone know where to find re-built
Below is my list of the ECUs and aps for the 70s EFI Cads. Note a
couple different numbers are a direct interchange. Probably a 79
with similar specs would be fine, also 79 Eldo, except the mounting
brackets don't fit a Seville.
Right, you can't really find these, and the ones you do find are
outrageously expensive, but may not even work. I suggest you
send your defective ECU to me and get it repaired and checked
out. I don't know of another repair facility.
Read about 70s Cad EFI on the first album of my PHOTOBUCKET
http://s93.photobucket.com/albums/L71/bcroe/
click on an Album
click on a picture to enlarge + description
BRUCE ROE bcroe@juno.com
5719 EAST SKINNER ROAD, CLC # 14630
STILLMAN VLY, IL 61084-9215 Phone 815 234-8039
76-80 Cadillac Bendix ECUs from Bruce Roe
Here is my list of early ECUs with application. I
believe some more late models may exist which
came out after my source of info.
Additions or corrections, let me know. Bruce Roe
Closed loop use an OX sensor.
E = Eldorado
K = Seville
C = full size rear wheel drive
Fed = 49 state application
Cal = California application
All = 50 state application
500 = 76 Cad engine
425 = 77-79 Cad engine
350 = 76-80 Olds engine
Orig = original part
remf = remanufactured or replacement part
Bendix # car desc
160 7250 76 K Fed orig 350
160 8339 76 E Fed orig 500
160 8340 76 E Cal orig 500
160 8341 76 K Cal orig 350
160 8820 75/6 C Fed remf 500
160 8822 75/6 C Cal/E Fed remf 500
160 8823 75/6 E Cal remf 500
160 8824 76 K Fed remf 350
160 8825 76 K Cal remf 350
160 8868 76 C Fed orig 500
161 0814 77 K Fed orig 350
161 0815 77 K Cal orig 350
161 0826 77 K Fed remf 350
161 0827 77 K Cal remf 350
161 1163 76 E/C Fed orig 500
161 1188 77 C Cal orig 425
161 1189 77 C Fed orig 425
161 1190 77 E Cal orig 425
161 1191 77 E Fed orig 425
161 1491 76 E/C Fed remf 500
161 1875 77 C Fed remf 425
161 1876 77 E Fed remf 425
161 1877 77 E Cal remf 425
161 1878 77 C Cal remf 425
161 2079 77 E Alt orig 425
161 2154 77 E Alt remf 425
161 2305 78 K Alt orig 350
161 2947 78 C Cal orig 425
161 2949 78 K Fed orig 350
161 2950 78 C Fed orig 425
161 2953 78 K Cal orig 350 open loop
161 4446 78 K Fed remf 350
161 4447 78 K Alt remf 350
161 4448 78 K Cal remf 350
161 4449 78 C Fed remf 425
161 4450 78 C Cal/79 C All remf 425
161 5137 79 E Fed orig 350 open loop
161 5139 79 E Cal orig 350 open loop
161 5173 79 K Fed orig 350 open loop
161 5882 78 C Fed orig 425
161 5883 79 K Cal orig 350 closed loop
161 6206 79 E Fed remf 350
161 6207 79 E All remf 350 open loop
161 6208 79 K Fed remf 350
161 6209 79 K Cal remf 350 closed loop
161 6210 78 C Fed remf 425 After Vin 223335, must use with blue (500) injectors.
161 8498 79 E Fed orig 350
161 8810 79 E Fed remf 350
161 9550 80 K/E Cal orig 350 closed loop
161 9551 80 K/E Cal remf 350
7 Nov 03, 20 Dec 10, 25 Nov 2012
