I don't know if this is the right forum for my request. I need an intermediate steering arm bearing! It's called new departure ball bearing! part number 900916? any direction could help!
I dont know where you would find one,but i have had good luck by googling the part numbers and search by images.Whenever im looking for something obscure like that i try it,has worked out nearly all the time,you might even try Ebay, search under the part number,you can even put it as a saved search and whenever it come up you will be notified.That bearing most likely was used in other places too. good luck harveyb
