The shop called, my cam is slightly off spec. Does anyone make a performace cam for the 390 engine?
I dont know of any new off the shelf ones but Im sure with enough money you can have one ground. I would call the major cam places like Comp and see what they can do for you.
Stampie
10-16-05
Joe, the shop that you are usuing should be able to ship the cam out and have it rebuilt to standard specs. I had an engine bored out by NAPA and they were able to send off the cam for rebuilding. (most shops that grind crank shafts also do cams)
Good Luck, Jim
P.S. there is a shop in TN that will build you a cam,cant think of the name just now. (time to goggle)
Kantner auto in Boonton NJ has the stock cam for $150.
I was hoping one of the major players had an off the shelf performance model, it looks like no one makes a performance replacement. I was given a phone # by someone at performance automotive warehouse in CA for a place in TN that can custom grind anything. Probabaly the same place you were thinking of.
Joe,
Isky used to do performance grinds years ago. They might still have some old stock.
Bruce,
The Tassie Devil(le),
60 CDV
Thanks for the update. I called them Isky, they can do a peroformance grind for me.
My motor is a vo-tech school. It should be done by Christmas.
Gday Joe,
You forgot to mention which Christmas.
Bruce,
the Tassie Devil(le),
60 CDV
Got me there Bruce, this christmas. So Ill have a toatlly rebuilt motor in a car, whose body work wont be done for at least two years. Well, at least I can open the garage door and run at idle a few times.
Gday Joe,
Dont forget to run the cam in properly before starting that Idle sequence.
Very important for the lifters as well as the cam lobes.
Bruce,
60 CDV
