1938 Cadillac Wiring Harness (60 65, 70, 75.)
Started by Mark Hewitt, September 01, 2007, 06:06:09 AM
0 Members and 4 Guests are viewing this topic.
Mark Hewitt
Were the wiring harnesses for 1938 Cadillac cars the same accross the the 60series 70 & 75 range of cars.?
IE, the main loom governing electrics for ignition, starter , lights , horn  ( relay ) under dash etc,
Separate looms would have been used for head lamps, tail lamps and indicators.
Thanks for any help.
harvey b
hello mark,i know this wont be much help to you,i have a 37 60 series and the wiring harness is one big peice,the only connecters are where the headlights hook up at the rad shell,it is complete right back to the tailights,we had a heck of a time to replicate it when we rewired my car,it was laid out on a long bench and we replaced one wire at a time the same length as the one we took out,and it even works??,in the 37 shop manual it shows a different wiring schematic for the larger series cars.i do not have a book on the 38s,but i know there is someone here that can tell you exactly what you need to know,this forum is great for this kind of stuff. thanks Harvey
Harvey Bowness
baxterculver
Quote from: Mark Hewitt on September 01, 2007, 06:06:09 AM
According to my parts book, the '38 60 series cars used a chassis harness # 1868202.  The 65 & 75 cars used a #1868204 and the 90 series used a 1868205.  So there are differences--how much I couldn't say.
I do know, for the '39 cars, that the 60 series (and la Salle) used a three wire voltage regulator while the big cars (75 & 90) used a 6wire regulator.  That would ialone would mply a different wiring loom.
The regulator part #s for 1938 cars show different numbers for the 38-50 & 60 series, and the 75-90 series.  I cannot tell you what those differences are.  Perhaps someone else can.
baxter culver clc#17184
Fred Zwicker #23106
Try Rhode Island Wiring in RI   401-789-1955.  They can furnsih whatever you need and have been helpful to me.
Fred
Doug Houston
I have the drawing from Packard Electric Division, GM for the dash harness for the 38-50,60, and 60S.  The harness for the 75, and possibly 65 will be different, brcause of the engine compartment, if nothing else. Then, the one for the 38-90 is again different, because of the primary starter relay located on the firewall. There is a small harness for the horn relay to the two horns. The connections to the light switch are a nightrmare before 1940 on all models!!
I bought a new harness from Rhode Island, and it's a magnificent piece of work.  Not in the car yet, but I hope to get it installed some time in the near future. It was about $525.00, as I recall.
Glen
Quote from: Doug Houston on September 01, 2007, 05:03:21 PM
Doug,
What series car do you have?  I need a wiring harness for my 38 model 7519.  Not that I’m anywhere near needing it; but I would like to get it so that I have it on hand.
$525 seems like a good deal.  How close did it come to the original in appearance?
Glen
Sorry about the thread hijack.
Glen Houlton CLC #727
CLCMRC benefactor #104
