1940 LaSalle rear main seal replacement
Started by 5219guy, December 09, 2007, 12:53:34 AM
5219guy
Is there such thing as a rubber seal for the 322 engine rear main or am I doomed again to the original rope type??
Roland # 8725
Roland Bleitz 5219
G'day Roland,
The Rope Seal will work if installed correctly.
The seal bust be forced all the way into the groove, and then cut off slightly proud so that when the cap is installed, the ends of the seal are forced together, without getting caught between the mating surfaces of the Main Cap to create an unwanted clearance problem.   Plus, a very slight smear of RVT sealant between the Cap and the Block will ensure that no oil can leak out under the cap.
The secret is to insert the "Rope" as per Factory Instructions, using a mandrel to seat it correctly.    I piece of round timber can do the job satisfactorily, and it gives you a surface to trim off the excess.
But also to make sure that the Crankshaft journal where the seal runs is totally clean and the return passages are also totally clear so that the oil can escape back into the sump, and not be able to be forced out to the outside.
baxterculver
Quote from: 5219guy on December 09, 2007, 12:53:34 AM
Roland # 8725
Mercedes makes a seal (#001 997 12 41) that seems to be of a composite material and is tough as nails.  It has been used in flathead engines with much success by many.  I installed it when I rebuilt my flathead and helped a friend install it in his engine without removing the crank.  Both engines are sealed tight!  Follow the instructions for fitting the rope seal, leave a little of it "proud" to compress it and fill the side grooves (where the cork is supposed to go) with an aerosol silicone filler and you should be go to go.
baxter culver clc#17184
Fred Zwicker #23106
[/quote]
[/quote]
Ditto on the Mercedes Seal # 001 997 12 41.  I had the engine for my 1939 LaSalle rebuilt by Shepard's Automotive in Akron and he ordered and installed the Mercedes Seal for this rebuilding.  However this was done when engine was apart.   It fit nicely and best of all - no leaks!   Attached is a picture of my engine after rebuilding.
Fred
Ah ha, I knew there was a good answer out there.   I forgot about the "Import" seal.
baxterculver
Quote from: Fred Zwicker #23106 on December 09, 2007, 09:53:07 PM
[/quote]
Fred
[/quote]
Fred,
I didn't mean to imply that the seal isn't best installed with the crank out of the engine.  That method is far superior and much more likely to be leakproof.  I mentioned that I had assisted a friend install the Mercedes seal in his flathead without removing the crank only to relate that it can be done.  We did it!  He didn't want to pull the engine out of the car but the rope seal had long since left it's job.  We loosened the center main cap to allow the crank to "sag" a bit, then pulled the new seal through the goove, using an inexpensive NAPA tool,  and seated it by pressing upward on the crankshaft.  The seal is inexpensive enough so he went for it thinking that the worst that could happen would be a continuing leaky rear main seal--at least until he could pull the engine out.  However, it works just fine.  He also replaced the rod and main bearings, stuffed in some new rings and was back on the road.  He drove the car (a '39 60S) from California to Colorado for the CLC Driving Tour and everything underneath stayed dry and oil free.  Those old flatheads were built to keep working and be easily maintained.
5219guy
Thanks for all the imput.
This has been a great help.
A friendly great bunch of fellow enthusiasts.
Roland---
Roland Bleitz 5219
Steve Matthews
I'm about to install one of these Mercedes seals in the flathead on my '41 60S - can anyone tell me if they should be installed dry or soaked in oil as the originals were?
Thanks-
Steve
Jeff Kay CLC#7630
You do not need to soak it in oil.  I just had this replaced in my flathead engine.  It is a pain to do with the engine in the car, but it can be done.  Just have patience.  Also, Napa Auto Parts sells a kit which really helps with the installation.
Here's the info on the kit:
Rear Main Seal Tool
Click on image to see enlarged view
  Item#: SER492
Price: $34.09
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Oil Seal Type:Wick & Neoprene Type Seals
Tool Grip Type:Chinese Finger-Type Grip
Additional Contents:Wick Seal Remover
Installer
Guide Funnels
Pusher
Offset Trimmer & Neoprene Seal Punches
