how to remove the horn ring from a 1957 cadillac
Started by Stan Pierce, July 01, 2008, 07:10:47 PM
Stan Pierce
I need to remove my steering wheel and horn ring.I can use any info on how to remove the horn ring from a 1957 cadillac .
Ralph Messina CLC 4937
Stan,
Look at the back side of the wheel / horn ring assembly. There are two Allen type screws that hold the horn ring in place. I don’t remember exactly where, but I believe they are in the space between the wheel spoke and the chrome horn spokes close the center. You'll likely need a flash light to see into the space.
HTH,
Ralph
2018 GMC Yukon
Doug 16070
#2
Ralph,
Thanks for the tip. My horn ring was loose & I was wondering  how to tighten it. It rattled quite a bit. Good to go now.
