Rochester 4GC Throttle snubber - 1966 Eldorado
Started by Peter Gidlow, September 15, 2009, 03:53:18 PM
Peter Gidlow
Hi Folks,
I have rebuilt my carb recently to a point where it looks a good as new, (lets hope it performs the same way  :-\
The one part I can't tidy up, although it still appears to function OK, is what I would describe as a 'throttle stop snubber'.  It's mounted on the left side of the carb assembly and slows down the throttle closing for the last 1/8" or so of its travel.  I assume to either prevent the motor from stalling due to the throttles snapping shut, or to give a smoother reduction in speed at small throttle openings in traffic ???
The main reason for the post is I need to get one from somewhere. I've tried getting one from this side of the pond, (the UK) and failed miserably.  Anyone know of a supplier?
The second reason for the post is, can I do without it if a replacement is not available?
Thanks in advance
Peter
CLC 23189
Otto Skorzeny
#1
Hi Peter,
Go to the technical section of this forum and look for the recent post entitled NEW huge list of Cadillac parts vendors.
Look for Daytona Parts Company and contact them regarding your carburetor needs.
fward
HUGE VENDOR LIST CLICK HERE
Philippe M. Ruel
#2
Quote from: Peter Gidlow on September 15, 2009, 03:53:18 PMwhat I would describe as a 'throttle stop snubber'.
Aren't you describing the anti-stall dashpot ?
Dashpots were mounted on almost every US car with automatic transmission through the sixties and seventies. They were not identical to each other but adaptations can be made. The purpose is to avoid stalling on deceleration while the car is running (no need on a car with a manual transmission, which draws engine upon deceleration).
You may do without a dashpot, as there is none on my '52 Rochester 4GC. But my car features a "hydraulic coupling" instead of a torque converter, some relationship remains between engine and transmission at any speed.
(Only to check if we are talking of the same thing) here is the dashpot on my 1966 Mustang Autolite carburetor.
1952 60 Special in France.
Dave Shepherd
Most Cads in my shop have anti stall dashpots that are no longer functioning, I set the idle just a tad higher and stalls are very rare.
Carfreak
CF,
He has a 4GC- The Quadrajet was introduced in 67.
By the way, there  are several carb shops that still have access to the aforementioned dashpots.  They were in production until recently.
Greg
Ralph Messina CLC 4937
2018 GMC Yukon
Dave Shepherd
Peter Gidlow
Many thanks for the info guys.
I'll go with the link from Ralph.
Regards
Peter
