Re: Bleeding air out of convertible hydraulics
Started by Rob Burt, November 08, 2009, 02:13:26 AM
Rob Burt
Hi,
    My 1966 Convertible appears to have air in the system , can anyone tell me how i can bleed this out or point me in the right direction.
When i go to put the top down , the pump runs fow approx 4 - 10 seconds before it takes up the oil , i've checked the reservoir and it's full (maybe more than it should be??) but i can see air in the hydraulic lines ???
Cheers
Rob
PS-I am an Aussie member of the Club , but cannot locat my number..
jaxops
This has been a trying morning getting these posted.  Here is the SOP, although in miniature thanks to the web post restrictions. It is the Fisher Body Manual for 1970, although it should be the same for your car.
1979 Lincoln Continental
jaxops
The last page- thanks crummy website!
Mark,
Why not send them to Rob Burt directly?  If you click on "email" in small letters below his name on the left side of his post it will open a blank email with Rob's address in it.  Then you can attach the photos that you posted here in a larger size to that email.  There is a way to do it here also (as a PDF file I believe) but someone else will have to to tell you how to do that.
There are lots of things you can do here with pictures and scans (multiple pictures, larger scans) that you just have to know how to do, I am not the one to tell you how though.   ;D
Geoff N.
Bill Hedge CLC 14424
Quote from: jaxops on November 08, 2009, 08:37:39 AM
G'day Mark,
If the website had no restriction on what size and number of pictures that could be posted, then everyone would be complaining that they couldn't open up messages till "after lunch".
As it is, it doesn't cost the viewers anything, so that in itself is worth the restrictions.
jaxops
Rob Burt
Rob Burt
Hi,
  Still having problems , the pump will run (with the top up) and nothing happens , if i manually lift the top about a foot or two then the hydraulics seem to pick it up.
The top will then work quite normally , if i then put it back up and take it down (again) then it all works OK , but if the top is let in the "up" or closed position for a few minutes , then it does the same thing again..
Should i be purchasing the air bleeder system that is shown on "Convertible parts" ??
Also looking for a new switch/controller , the current one is OK , but i would like to get a spare. The convertible parts website does not seem to have any for a 1966 Cadillac , are there other sites that i could look at??
Any help would be very appreciated..
Cheers
Rob
CLC#17483
Chris Conklin
Check with Cadillac Tim for a switch, he may have some more. He was the best price I found as well, but you need to send him a replacement core.
tagroves@wctel.net
Chris Conklin
Ian clc#20080
G'day Bob,
I used a length of 5/16 isd oil/Trans Cooler tube.  At one end I crudely ground down the outer diam of the tube for about 3/4" so that it made a tight fit into the filler plug hole.  I then ran the tube down to a bottle of trans oil on the floor of my '65 convertible.  I cycled the roof up and down a couple of times and all was well. Still has a few bubbles in the lines but it runs ok.
Good luck.
Regards,  Ian.
dave_wa
Hi Rob
Give me a call direct, and I will see if I can help (0401 100 288). I have a bleeder kit you can use if you wish. I live near Armadale WA.
All the best Dave
Dave Batger
CLC# 24083
Perth - Western Australia
1958 Cadillac Convertible
1959 Cadillac Series 75
  Ahhh, you got me!  I thought at first you were in the state of Washington (WA), USA.  The phone number had me going!  Too early in the morning for me I guess.
;D  Geoff N.
G'day Geoff,
Yes, that phone number is a Mobile Phone Number here in Australia.
