57 wiper system
Started by Peter Nieuwlandt, October 19, 2010, 01:40:05 PM
Peter Nieuwlandt
Hi
The wiper system  on my 1957 Cadillac , wich is mounted under the dash (  left and rigth axle shafts,wheels and cables)is severly messed up.
The former owner had trouble with it and had a "mechanic" work on it.
I took apart the dash and found that the cables have been cut,the wheels are missing parts and bits and the left side shaft (steering wheel side) is really messed up.
So I'm looking for a complete system from a donor car.
Can anyone help?
Peter
CLC 17863
Peter Nieuwlandt
CLC 17863
cadparts58
Peter,
  I have the left and right 1957 transmissions. The cables are intact and all the parts for the transmissions are on it. If you want I can email you direct with pictures. Asking $50 for the pair. Also 1958 transmissions will not fit without modification because the shaft diameters on the 1958 is larger. Hope this helps. Frank Puma #10721
Frank Puma #10721
Peter Nieuwlandt
Hi Frank,I emailed You on the transmissions
Peter
Peter Nieuwlandt
CLC 17863
cadparts58
Peter,
My email has changed and I forgot to update it on the message board. It's fpuma49@verizon.net Sorry about that
Frank Puma #10721
Peter Nieuwlandt
Frank
I emailed You at Your new adress
Peter
Peter Nieuwlandt
CLC 17863
Bill Hedge CLC 14424
Peter:
You have email.
Bill Hedge  CLC #14424
Forum Administrator
57flw
Hi Peter,
I don't know if you need this or not but I have provided a photo of the cable sysytem from my 1957 Fleetwood.
Hope it will help you.
Regards
Ken
Ken Francis
Hervey Bay
Queensland, Australia
1957 Series 60 Special Fleetwood
Skype: fleetwood1957
Peter Nieuwlandt
Bill
I 've been trying to change it for several times now, but it won't go through...............?????
The password wich I noted down when I created the profile won't work !!!
Can You help???? I'm trying to get it rigth but I guess I'm a little better at Cadillacs than computers....................
Peter Nieuwlandt
CLC 17863
Peter Nieuwlandt
CLC 17863
Peter:
I just saw your message and your issue should be resolved soon.
Bill Hedge, CLC #14424
Forum Administrator
Peter Nieuwlandt
Peter Nieuwlandt
CLC 17863
Peter Nieuwlandt
Thanks Ken
Yes Your picture is helpfull
Peter
Peter Nieuwlandt
CLC 17863
Bill Balkie 24172
Bill Balkie
1970 Coupe DeVille
2009 CTS
Peter Nieuwlandt
Thanks to the guys that helped out in getting me the parts that I needed to repair my wiper system.
Only now I find out that I will need the wiper arms too !!!!
I guess they got damaged when the previous owner tried to "fix" the problem.....
So if anyone has or knows where to get two nice wiper arms for a 57 or 58 please let me know !!!!
Thanks again
Peter
CLC 17863
Peter Nieuwlandt
CLC 17863
