1937 60 series rear axle seal replacement
Started by harvey b, August 31, 2011, 09:03:00 AM
harvey b
Hi All, have a 37 60 series that has a bad seal on one side of the rear end,any body know what seal i need,have a MPB and it shows a seal part # 1418889,Have a local parts supplier looking for one,but was wondering if anyone here had a number i could use to speed up the process,dont have the room to dismantle the car first,then go looking for one,MPB shows it fits up to 48?it is the seal at the outer end of the axle,Also any tips on how to do the job,seems straight forward,but you never know >:D,  Thanks Harvey B
Harvey Bowness
Frenchfort PEI
Harvey Bowness
Jeff Maltby 4194
Harvey. Either google 1937 cadillac axle seal or do a search on the boards. All cads of the 40's/50's has your seal in stock. Check with napa also.
1937  CAD. AXLE REMOVAL... - Cadillac & LaSalle Club
www.cadillaclasalleclub.org/.../1937-cad-axle-removal-seeking-tips-... - Cached - Block all www.cadillaclasalleclub.org results
Not helpful? You can block www.cadillaclasalleclub.org results when you're signed in to search.www.cadillaclasalleclub.org
You +1'd this publicly. Undo
Jul 6, 2011 â€" 1937 CAD. AXLE REMOVAL...Seeking Tips, Tricks or Advice Please. ... of the axles on my 1937 Series 75 Cadillac in an attempt to install new rear axle seals. ...
1948 75 static collector on the rear drain shields - Cadillac ...‎
1940 LaSalle pinion seal replacement instructions - Cadillac ...‎
1937-1948 cadillac parts for sale‎
More results from cadillaclasalleclub.org »
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
harry s
Harvey, According to the shop manual the series 60 axle seals are outboard unlike the series 75 which are inboard. A real pain to change. The manual also advises to keep the axle vent holes clean. The series 60 are located on the top of the axle housing while the series 75 is located on the bottom near the drain. A pressure buildup in the axle housing will cause the seals to leak. Good Luck, Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Classic
According to NAPA, seal part # 1418889 crosses to their # NOS 15975 (CR-Chicago Rawhide).  Also crosses to National # 450274:
Type Of Product:  Oil Seal - Inches
Shaft or Inside Diameter Range:  1.594"
Bore or Outside Diameter:  2.762"
Width:  1/2"
Lip Material:  Nitrile Rubber
Construction Description:  Single Lip, Spring Loaded With Inner Case
Seal should be readily available through any auto parts store or through a bearing distributor.  Also available on Amazon: http://www.amazon.com/National-Oil-Seals-450274-Auto/dp/B004ABENIU/ref=sr_1_1?ie=UTF8&qid=1314885437&sr=8-1
Gene Menne
CLC #474
Steve Passmore
I don't remember the number of the seal Harvey but as its already been said the seal is on the outside and easy enough to do.
You will need a puller to remove the rear drum, then a circle of bolts holding the seal and bearing in place along with the backplate, withdraw the shaft and extract the seal.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Brad Ipsen CLC #737
I know this is a repeat of things I and others have said before but while you are there replace the bearing on the axle.  They fail.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
