1968 Eldorado (similar on all 472's) frozen distributor-can't set timing
Started by Scot Minesinger, May 16, 2012, 11:58:50 PM
The distributor will not turn on the 1968 Eldorado with 472.  It is frozen.  The distributor is delicate and so have to be careful (not made of iron like block).  The car has 36,000 original miles on it and it has probably never been changed from the factory setting.  Any ideas on how to free it up?  We have tried many tricks to no avail, I'm an amateur mechanic.
G'day Scot,
The only way to free it, without snapping it off is to soak the base, where it enters the block with a penetrating oil, and keep of spraying it.
A bit hard to do any tapping with a hammer or drift from underneath, but anything should help.
If you can place a damming material around the base, as in plasticine, or even create a moat effect around the piece with JB Weld, then fill the "moat" with the penetrating oil, it will eventually seep down, and hopefully become free.
I had this happen with a Ford Cleveland motor, and eventually got it out.
Glen
Use a 50/50 mix of automatic transmission fluid and acetone.  Works better than any commercial penetrating fluid.
Your problem is caused by the dissimilar metals.  The distributor is made of aluminum and it reacts with the steel of the block.
Use anti-seize when you reinstall it.
Glen Houlton CLC #727
CLCMRC benefactor #104
Glen and Bruce,
Thanks, seem like very helpful suggestions!
Scot
Gene Beaird
I was thinking oil is caked around the distributor and distributor hole in the block, essentially 'gluing' the distributor to the block.  It could be electrolysis, too.  The ATF/acetone sounds like a great trick, for both issues.
Just make sure you locate the distributor rotor and vacuum advance port, like you would if you are going to pull the distributor for work there, because you will probably end up pulling the distributor.  I just want to make sure you don't start concentrating on the issue of moving the distributor, and then all of a sudden it's sitting in your hands, out of the car, and you think "Awww cr@p, I don't know how everything is clocked!"
When you get it loose, go ahead an pull it, and really clean the distributor housing where it goes into the engine so you can hopefully prevent this in the next 36,000 miles.   ;)
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
