2003 CTS Power Window Switches
Started by Matt CLC#18621, November 18, 2012, 03:06:05 PM
Matt CLC#18621
Power Windows on all passenger doors do not work on 2003 CTS; however, they all operate via driver's window switches?
Matt
CLC# 18621
Matt CLC#18621
Matt
CLC# 18621
Glen
Does this car have the lock out switch that prevents passengers (kids) from operating the windows?  It would most likely be with the master switch for the driver.
If not then you probably  need to look for a blown fuse.
Glen Houlton CLC #727
CLCMRC benefactor #104
Matt CLC#18621
Yes, it has a master switch.
Matt
CLC# 18621
