1957 Cadillac Sedan Battery Grounding
Started by Coupe Deville, September 22, 2013, 02:03:26 PM
Coupe Deville
Hello. I think my 1957 Cadillac series 62 Sedan does not have the right negitive battery cable and i dont think it is grounded in the right place either. Does anyone have pictures of this or where i could get a O.E. style cable?
-Gavin
Walter Youshock
The negative cable attaches to the frame rail with a bolt.  You'll see a hole on the top of the frame just in front of the rad support.  I know I must have a picture but have to find it or snap another.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Coupe Deville
Thank you. That explains alot. My battery is currently grounded to the radiator support For some odd reason. Also what voltage do I need to crank the engine successfully? My battery is 6 years old and holds a charge of 11.5. My engine bearly cranks over. Is this a battery problem or starter?
-Gavin
Walter Youshock
Battery sounds weak OR it's the grounding location.  Original batteries leaked--on the grille and down on the frame where the ground cable bolt should be.  Mine also leaked on the passenger steel brake line and ate a hole through it!
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
David Greenburg
Make sure that the cable is bolted to bare metal on the frame/body.  Paint or rust can cause problems like this. One way to test would be to clip a good quality jumper cable from the neg. terminal to a known good ground and see if that helps.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
raul.kolk
#5
Sorry to awake a dead thread, but it seems rather reasonable to post here than start a new one.
I as well have a question about battery grounding strap location. On 57-6267SX in my case.
I read from July '99 '57-'58 Cadillac Authenticity Manual Page III-10 that "The ground cable is bolted to the top of the frame rail. The ground connection to the battery is made closer to the battery (further forward along the right frame rail). Taken that the 7.2910 STRAP, GROUND, BATTERY is 21 1/2" lg. as stated in MPL, it leaves not much openings to be attached to, but none available seems quite right. I doubt that any of them has been welded before the paint job, but you never know. If anyone could refer to correct attaching point I'd be really thankful.
