39 LaSalle body parts same as Olds and Buick ?
Started by las39, December 29, 2013, 08:57:34 PM
las39
The rear body panel of my 39 LaSalle 5027 is a bit rusted and dented and was planning to fix this.
Also my left lower A pillar has some rust.
Will body parts for 1937/38 Buick-Pontiac-Oldsmobile fit ?
I have found these two suppliers. Are there others?
http://www.exploringthenorth.com/kemp/replacement/parts.html
http://c2cfabrication.com/store/advanced_search_result.php?keywords=lasalle
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
Steve Passmore
Yes, the Buick 40 and 60 series is the same as long as its the same year and body style. Pontiac too but I believe Olds is smaller.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
las39
Quote from: S Passmore on December 30, 2013, 05:21:46 AM
Thank you and Happy New year
1939 LaSalle 5027
1934 Oldsmobile F34
Barry M Wheeler #2189
The "B" bodied Olds is the same. There were some "A" bodied Olds I believe as well as Pontiac and Buick. BUT, you have to use the correct year. 1937 and 1938 are the same. 1939 and 1940 are the same. You need parts for a "B" bodied car. Thus, the 1937/38 parts shown on the first supplier will not work. I couldn't check the second as my Norton type blocker said the site was unsafe.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
las39
#4
Quote from: Barry M Wheeler #2189 on December 31, 2013, 04:11:56 PM
Thank you Barry. So no luck for me to change the back panel as they only sell for 37/38.
The other site has 39 rocker and toe panels.
Do you you have any idea where I can purchase the rear body panel.? Attached screen dump of the last site
1939 LaSalle 5027
1934 Oldsmobile F34
