Choke tube
Started by tturley, September 27, 2014, 05:24:14 PM
tturley
I need to replace the tube from the exhaust manifold to the choke on a flathead v-8.
Does it matter what material is used ? Copper steel aluminum ?
Member # 28929
1940 Lasalle model 5019
2011 Escalade platinum Edition
1995 Ford F-150
2015 Buick Enclave
Steve Passmore
I've got copper and steel on my cars, never seen aluminum though.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Aluminum is what you get if you go to a parts store.   Its sold under the Doorman / Help line.
tturley
Thank you for the comments. Mine had aluminum but it looked terrible. Bends all pinched almost closed.
I could not find the same material so I used copper but did not know if the copper might conduct the heat more and create an issue.
Member # 28929
1995 Ford F-150
2015 Buick Enclave
las39
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
joeceretti
I used a brake line. It happened to be a VERY close green colour to the paint on the engine. I am sure it isn't correct but will remove it at a later time and remove the green coating on it but for now it functions very well.
