Couple questions about a 40 lasalle
Started by tturley, May 20, 2015, 02:32:02 PM
tturley
Getting ready to paint after full body restoration and am wondering if clear coat was used on the inside of hood. Is it ok to paint the inside of fenders black on a maroon car?
Also need some bumper bolts and they are tapered on the end for alignment , any suggestions
Member # 28929
1940 Lasalle model 5019
2011 Escalade platinum Edition
1995 Ford F-150
2015 Buick Enclave
Doug Houston
Check me if I'm wrong, but hood undersides were generally a flat black.
Fender interiors were often, if not always, body co.or. Yours would be maroon.
Regarding bumper bolt, try checking the AuVeCo re-packaging servic at your pats store. Thete should be a be a  variety of bumper bolts available.
38-6019S
38-9039
39-9057B
41-6227D
41-6019SF
41-6229D
41-6267D
56-6267
70-DeV Conv
41-Chev 41-1167
41 Olds 41-3929
gary griffin
I don't think clear coat was originally used in 1940.
Gary Griffin
Fred Pennington 25635
Authenticity Manual Says;
under hood, and underside of fenders: Semi Gloss Black
The body was painted without the fenders so the visible body area on the rear (behind the tire) will be body color.
I makes sense if the the back sides of these parts was painted semi gloss black and the outside was painted separate from the main body.
They had no reason to paint what was to them the underside.
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
tturley
Thank you Fred
I missed that in my guide.
Painting right now
Member # 28929
1995 Ford F-150
2015 Buick Enclave
