1937 60 crankcase vent system
Started by Steve Rinaldo, May 25, 2015, 04:28:38 PM
Steve Rinaldo
While doing some work on 1937-60 I notice that there was a coating of oil in the air filter,carb top and other areas around the air cleaner. I know this system is supposed to draw crankcase fumes [ but not oil] into the engine at the back of the filter can. My understanding this was a 1 year design. I am thinking about teeing the two engine pipes together and making a old style road draft system. Any other thoughts or ideas. Steve
Joe,
It was used in 1937 and 1938 as was the electric choke.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
Steve Passmore
If the breather is pulling oily fumes through this system it usually means a tired engine. Too much back pressure from worn rings or bore will cause this. The later system just dumped this stuff on the road.  It may be possible to use one of these after-market valves in the pipe that filters the oil particles out.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
Joe G 12138
 For what it's worth, the "37 is kind of an oddball in that it has no rear main oil seal; possibly no front seal either. Some have adapted PCV valves to later flatheads, but I'm not sure how this would work on a non-sealed motor as far as being effective, vacuum leaks, etc. Would converting to a road draft tube cause more rear main bearing oil leakage on a '37? could that goofy but messy vacuum tube  be the best choice for a '37??
          Joe Gibeault 12138
