58 SDV: Brake issue (Delco)
Started by wbdeford, September 14, 2015, 08:24:46 PM
wbdeford
update: Booster is completely disassembled, except the push rod is still connected to the air valve (manual says you don't have to take that apart unless it is loose or noisy).  All booster parts look to be in good shape.  Cleaned everything in alcohol as the manual directs.  Ordered tool J-5794, so will disassemble the master cylinder when that arrives.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1958 Miller-Meteor Futura Landau Duplex
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
wbdeford
Anyone have a parts diagram of the '58 Delco master cylinder?  The '58 shop manual supplement mentions a spacer that was not in mine.  It only has a picture of the end plug parts and not the whole MC.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
J. Gomez
William,
I do not have one specific for the 1958, maybe the generic one that came with a rebuilt kit can be of help.
I’m having difficulties attaching the file for some reason, send me a PM with your email and I’ll be glad to send you a copy.  :(
Good luck..!
J. Gomez
CLC #23082
wbdeford
Thanks....PM'd you my email.  The '58 system seems to be unique.  I have '57 and '59 manuals and little seems the same
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
J. Gomez
Quote from: wbdeford on September 24, 2015, 10:28:29 AM
File send..!
J. Gomez
CLC #23082
wbdeford
Update: booster and master rebuild are complete and reinstalled on the car.  I bled the master cylinder with it on the car (the only procedure given in the shop manual).  Should I expect very much air to have gotten in the main line while bleeding the master?
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
Jon S
Yes. You will need to bleed all of the wheel cylinders starting with the right rear
Jon
1958 Cadillac Sedan De Ville
1981 Corvette
2004 Mustang GT
wbdeford
I know I need to bleed them--just wondering how much air to expect--just a little because it disconnects from the master at the high point, so little air gets in?  Or a lot because bleeding the master puts a lot of air into the lines?
One reason I ask this is that I will be pulling the car out of the garage to bleed the wheels and want to know how diminished I should expect the brakes to be.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
Jon S
If you did not bench bleed the master first there will be at least 3 cycles per wheel cylinder (pump/open/depress/close). Maybe you will be lucky and experience less.
Jon
1981 Corvette
2004 Mustang GT
wbdeford
I am planning to use a quart of brake fluid and flush out the lines completely.  Sounds like I should expect very little braking power when I pull out of the garage....
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
Jon S
Agreed. Hope your parking brake works well. Also wait for the idle to slow down before moving the car. Good Luck!
Jon
1981 Corvette
2004 Mustang GT
wbdeford
#31
It's actually a good thing....if you said the pedal should be mostly firm already, I'd be worried, cause it ain't now :)  Fortunately, my driveway is very friendly for this....yes, definitely will wait for slow idle.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
wbdeford
Bled the brakes and got a firm pedal....but the power brakes were only partially working.  I thought perhaps the hose inside the booster was collapsing, so I replaced that....seemed to have a slight improvement, but still not much better than manual brakes.  Went back to my pictures and realized I put the reaction plate on backward.  I can't imagine how I did something so dumb, but that's exactly what I did.  Disassembled the booster, partially disassembled the piston, and turned the reaction plate around like it is supposed to be.  Put all back together and re-bled the master. "voila"....the brakes work perfectly once again.
Good news about this is, I am now very efficient at removing and replacing the power brake assembly.  Can take it off the car in about 5 minutes.  A little longer going back on.
1958 Sedan de Ville
Past:
1960 Coupe de Ville
1979 Sedan de Ville
1980 Seville
