76 Eldorado Master cylinder
Started by cadillacrandy, June 08, 2016, 12:48:46 PM
cadillacrandy
My 76 Eldorado seems to have a brake fluid leak. It seems to be at the master cylinder. The rear chamber is the one going down in fluid, which is for the front brakes.  What do you recommend to fix it. Would you rebuild the master cylinder or replace the master cylinder? If rebuilding the master cylinder, is it a difficult job and is there a rebuild kit available?
wbdeford
Brand new at Autozone for $43 or a remanufactured one for $20.  Lifetime warranty on both.
1958 Sedan de Ville
Past:
1956 Fleetwood 75 Sedan
1957 Fleetwood 60 Special
1958 Miller-Meteor Futura Landau Duplex
1960 Coupe de Ville
1966 De Ville Convertible
1970 De Ville Convertible
1971 Eldorado Convertible
1979 Sedan de Ville
1980 Seville
It could be a brake line, a brake piston, and etc.
bill06447
The front lines will leak underneath the clip that secures them to the frame at the cowl-they crack and the fluid disappears with nary a trace
Bill
cadillacrandy
Quote from: wbdeford on June 08, 2016, 01:52:08 PM
Thank you William. Great information
cadillacrandy
Quote from: Scot Minesinger on June 08, 2016, 07:10:59 PM
thank you. I will look closer
cadillacrandy
Quote from: bill06447 on June 08, 2016, 08:06:45 PM
The front lines will leak underneath the clip that secures them to the frame at the cowl-they crack and the fluid disappears with nary a trace Thank you Bill for that tid bit of info. I will try and find where you might be talking about on the frame. Thank you
Bill
Jakes
With all due respect to an earlier post, I'd be suspicious about a $43 new M.C. or a $20 rebuilt unit.  At those low prices I'd suspect that they are Chinese made knock-offs.  Like anything else you get what you pay for.  You can get a new ACDelco for about $85 or the Raybestos rebuild kit for about $22 from Rock Auto.  The M.C. is made in Mexico which I'd trust more than China.  Debatable??.. perhaps, but 43 bucks for a "new" unit sounds too good to be true...
Paul
'78 Eldo. Custom Biarritz Classic
I would consider a replacement but keep my old one if it appeared to be an original.   IF you do keep your old one you will want to disassemble it as far as you can and clean it up then spray it down with some anti rusting agent.   If you just throw it on the shelf full of brake fluid it will just become a rusted mass that may be very difficult to rebuild if you ever decide to.
