57 power windows
Started by Cadillac Jack 82, July 15, 2016, 02:39:48 PM
Cadillac Jack 82
Where is the fuze located for the power windows?  My windows work fine normally but sometimes I get in my car and the switches do nothing...but will work again shortly afterwards.  Bad ground maybe?
Tim
CLC Member #30850
1959 Cadillac CDV "Shelley"
1964 Cadillac SDV "Rosalie"
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1955 Packard Clipper
1957 Cadillac Series 62
1962 VW Bug
1962 Dodge 880
1966 Mercury Montclair
1968 Chevy Chevelle SS
1968 Plymouth Barracuda
1977 Lincoln MKV
Jeff Rosansky CLC #28373
If it is a fuse then when it is dead it will stay dead. A fuse won't reset itself. Now there may be a relay that is bad but that would be a different issue.There could be a resettable breaker that is bad. Will need to check your manual.
Jeff Rosansky
Cadillac Jack 82
Tried that I'm trying to locate the window relay.  Is it behind the dash?  Its definitely not by the fuze box
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
Relay is on the driver kick panel.  I'd check the wires going to the door.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
Its all the switches though.  I think the heat might be doing it.  They were fine last night
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
If the master gang switch isn't getting power, the individual switches may not work.  Did you pull the driver switch and check the contacts on the wired circuit?  Try jumping them and see if the windows work.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
The windows work now...but now I'm getting a flicker on my gen light every minute or so.  Think my regulator may be adjusted too low causing the battery to drain
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Cadillac Jack 82
Now the GEN light flickers every minute very lightly
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
Walter Youshock
At idle or while driving?  Could be regulator but I'd look at the generator brushes and commutator.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Cadillac Jack 82
At idle.  Nothing happened when I was driving its only when its parked
Tim
CLC Member #30850
Past Cars
1937 LaSalle Cpe
1940 Chevrolet Cpe
1941 Ford 11Y
1954 Buick 48D
1955 Cadillac CDV
1962 VW Bug
1962 Dodge 880
1977 Lincoln MKV
