1957 Eldorado Biarritz question
Started by zgusto, October 31, 2016, 05:19:30 PM
zgusto
Still searching for a 57 Biarritz convertible....What is with the gold wheels I keep seeing? Was that an option? What wheels should come on it or could come on it and if I want a set of those, what I am going to probably pay.
Thanks in advance for your knowledge!
D.Yaros
Gold anodized sabre wheels were available as an option.
Dave Yaros
CLC #25195
55 Coupe de Ville
92 Allante
62 Olds
zgusto
Quote from: D.Yaros on October 31, 2016, 05:35:26 PM
Thanks!!
What other wheels were factory options or standard????
Walter Youshock
Gold sabers were ONLY available in 1956.  They will not fit the front of a '57 because of the larger brake drums.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Quentin Hall
I've seen many 57 Biarritzs running incorrect 56 gold sabres. Always looks wrong to me. I guess they may have shimmed them on the hub. The correct sabres for a Biarritz are chromed with a red medallion plastic crest.
PS my brother once changed my tire and the spare was a 56 sabre. I meant to tell him I had washers to space against the hub but got sidetracked. He cranked the lugnuts as he is prone to do and warped the front drum.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Barry M Wheeler #2189
I had a 1957 convertible for some time way back when, and found that the two "best" Sabres that I had would not fit on the front drums as they were the earlier ones. (Both early and late fit on the REAR wheels with no problem.) I had a friend who had a beautiful 1958 Biarritz that had gold wheels from the factory. His story was that to get rid of the stock of leftover 1956 gold wheels, they offered them with a specially cast spacer to fit on the newer brake drum.
It was cost effective to sand cast the spacer and get rid of the excess wheels. So, gold wheels on a 1958 Eldo are factory correct. You'll have to take up gold on the 1957s with Bill Anderson...
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
Walter Youshock
That is an interesting bit of info.  Definitely worth investigation.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
