1960 Cadillac stock rim size
Started by 60eldo, June 23, 2018, 08:34:58 PM
60eldo
    Correct me if Im wrong but the eldorado rims are bigger than standard deville rims. In order to put an eldorado hub cap on a deville rim, it will not fit . Eldorado rim is 16 1/8 which means the eldo cap wont fit on a deville rim, deville rims a 16",,,confused yet?
Jon. Kluczynski
Bob Hoffmann CLC#96
Jon,
You REALLY need to buy a MPL that covers the 1960 model year. You would be able to answer many of your own questions & dispel "urban" myths!
Bob
60eldo
Jon. Kluczynski
Jon
That's a master parts list.
Eldo and Deville rims are the same. The tangs on the hubcaps need to be bent and adjusted to fit the rims securely. Especially the heavier Eldo hubcaps.
The Eldo caps dent very easily even with a rubber mallet.
Some guys fit them and also use a bead of clear silicone to glue them on.
cadillacmike68
And neither one of them is 16" They are 15"
"Cadillac" Mike
I am guessing that 15" is the measurement at the tire bead and Jon is talking about the very outer edge.
60eldo
yes, outer lip to outer lip. I had a guy years ago with a 60 eldo and he wanted to buy a rim from me cause his eldo cap wouldnt fit on his 16 in rim, he made me measure mine 16 1/8. it had to be.
Jon. Kluczynski
cadillacmike68
Quote from: 60eldo on June 24, 2018, 02:54:43 PM
If you are off center by less than one inch the diameter reading will be off at least that amount.  The proper rim diameter measurement is the bead diameter and the ElDorado wheels were the same as all the other non Series 75 / CC wheels back then.
"Cadillac" Mike
