1970 Lower Control Arm
Started by Jeff Rosansky CLC #28373, September 25, 2019, 08:50:09 AM
Good morning.
Well the upper control arm bushings on our 70 have destroyed themselves. My guess is that before I got the car they were replaced and not torqued with the wheels loaded.
Anyway, as everyone knows, it isn't the job you are doing, it is the Might as Wells. Well, I might as well do the lower bushing while I am at it.
I have read the manual of course but I admit I am a little intimidated about unloading the spring. I certainly plan to be off to one side when I do it but any tips and tricks would be appreciated to SAFELY unload and reload the spring. Upper control arm is still off the car.
Jeff Rosansky
I'm not an expert but I think it was a good call to replace those bushings.
If you think these are bad, you should see my tires.
Jeff Rosansky
klinebau
Following the service manual is a good start.  I looped a chain around the spring and frame for extra safety.  You also need to make sure the car is high enough to fully drop the lower control arm.
It will be difficult to remove the spring otherwise.  Sometimes freeing up the lower ball joint can be a pain.  smacking the knuckle in the area of the joint on both sides simultaneously worked for me.
I really didn't find removing the springs to be very scary, however reinstalling the springs is a different story.  The angle of the control arm makes it very difficult to raise the spring without the control arm slipping off the jack.  I found it much easier to compress the spring first with an internal spring compressor.  I also had trouble getting the spring to seat in the pocket correctly on the passenger side and had to use a pry bar with the spring compressor to keep it aligned.
One other thing you need to do is internally brace the lower control arm when pressing in a new bushing.  The service manual shows a special tool, but you can improvise.  I used a piece of exhaust tube that I sectioned out.  You will ruin the control arm if this is not supported correctly.
Detroit, MI
chrisntam
When you press in the replacement bushings, BE SURE they go into the arms at the correct depth.  Dood who did mine pressed them in too far and I had to get junkyard lower control arms...
1970 Deville Convertible
Dallas, Texas
Jeff,
Yes I have done this job several times.  The spring position (how it is clocked) so that it is even with lower control arm as per manual is not easy, but you must do it.  I just followed the manual and no problem worked fine.  I bought a press for $100 on Harbor Freight and that has done about a dozen Cadillac suspension press works for me.  The Eldorado is more difficult.
On the might s wells, yes I media blasted and powder coated everything.  The photos are from a 1970 SDV.  It helps when you have free teenage labor to media blast and handle all the no fun work.  I did not media blast or powder coat the spindle because it is heat treated, that was sanded and painted.  This was back in 2013, and it still looks new.  Drives and rides like a dream.
Jeff,
Coming in late here and looking at the pictures of the A'arms I would be very careful to check and verify everything for proper dimensions and correct size bushing holes.  Improper removal and installation of both upper and lower (lower are subjected to even more abuse during operation and bushing replacement) can distort the arms making repairs difficult.
64\/54Cadillacking
Control arm bushings are one of the most overlooked suspension components when it comes to how ours cars ride and handle.
I remember years back when I owned my 94 Fleetwood Brougham, the upper and lower  control arm bushings were trashed and the car rode rough and handled like crap.
After all new bushings were installed, the car drove like It was new. It was quiet, and the bumps in the road were barley felt as the bushings absorb road shock. Sure tires and shocks can make a difference in ride quality, but I believe a fresh set of control arm bushings in many ways is more important and had a bigger effect on ride isolation and smoothness.
Replacing them is PITA but it isn’t hard to do when you have the right tools.
Currently Rides:
1964 Sedan Deville
Previous Rides:
1987 Brougham D' Elegance
1994 Fleetwood Bro
1972 Sedan Deville
1968 Coupe Deville
1961 Lincoln Continental
#7
Thanks guys.
I had a jig set up to press in the top bushings last night but it didn't quite work as planned. I see the tool in the book and tried to make something but it wasn't strong enough. Will move on to plan B later.
Glad to know others have safely unloaded the springs at home. I tend to get intimidated by things that could kill me. That, I think, may be an advantage to age.
Jeff Rosansky
klinebau
Quote from: Jeff Rose                                         CLC #28373 on September 26, 2019, 10:53:09 AM
Thanks guys.
I made the tool exactly to spec from the service manual.  You are welcome to borrow it if you want.
Detroit, MI
Quote from: klinebau on September 26, 2019, 11:20:59 AM
PM sent
Jeff Rosansky
That tool in service manual to press out the bushings is worth making.  It is easy, drill, metal saw, and file or grinder is all it takes.  Plus, it works on numerous other Cadillac and GM makes.
