1965 cadillac 429 engine not priming oil on start up
Started by R.Miller, August 28, 2019, 11:25:26 AM
R.Miller
 My 1965 Cadillac with a 429 cu.in, engine will not pick up prime on start.
We rebuilt the engine completely , primed it and ran it on the DYNO foe 1 1/2 hours everything  worked fine.  At idle we had 17 lbs psi and at 3300 RPM it read 38.9 PSI . We restarted the engine 12 times no problem , let it sit in the DYNO for 3 days and restarted it again with NO ISSUES. We then installed the engine , keeping it level the oil full with same filter undisturbed from the DYNO runs. We have no oil at the oil sending unit port at all now that its been put in the car. What could be the cause of this issue. I have 40 years experience on car engines and never seen anything like this . All clearances and end play was measured and within specs concerning the pump , part number on rebuild kit is also correct. Anyone have any ideas or suggestions would be appreciated . I really want to keep this car stock but I have a 650 hp Dart 350 sitting in the shop waiting for something. So far the car is completely stock and that would be a shameful thing to do.
Thank You
R.Miller
Will it prime eventually or is it not working at all at this point?   If its dead are you sure the pump is turning?  Maybe is a drive issue?
What is the pickup tube setup like on the 429?   Any chance something could have come loose moving the engine around?
The 429 has an external pump.  I would suggest pulling the distributor and turning the pump with a long shaft (I made my own) in a 1/2' drill motor.  Maybe once it is primed again it will be OK or at least it may point to the problem.
I believe its like the Buicks where most of the pump is in the timing cover and the pump cover holds the filter and maybe the bypass valve?   If the pump cover is also what holds the filter is it possible that maybe it got banged with moving or installation and maybe cracked the cover?
Ralph Messina CLC 4937
The dyno test pressures indicate the pump clearances are within spec and it was operating correctly. I would follow Geoff’s suggestion to remove the distributor and turn the pump shaft with a drill - clock wise. If it does not turn or make rattling sounds,  something mechanical is broken or out of place. If it turns but does not self or hold prime, I would drop the pan and check the junction of the pick up pipe and the oil pump case . That junction must be secure because an air leak would interrupt the siphoning action resulting in less or no oil draw. I don’t recall whether there’s an “O” ring on that pipe.
2018 GMC Yukon
Here is how I prime those situations.  I roll up another car with fresh
oil and connect a 6 foot high pressure hose (trans pressure gauge)
between the 2 oil pressure switch ports.  Idle the other car for 30 sec
and then check the oil.  When it is down over a quart, I stop and start
starter cranking the new engine, plugs out.  Check a few times, when
the the oil levels are back to normal, you are done and the new engine
is fully lubed.  Works, no stress or danger of damage.  Bruce Roe
#6
If you are able to get oil flow by manually turning the pump as described and it keeps price you are set if it continues to loose prime there are three things that often are the culprit.
First of all the pick up may have come loose.
Secondly the gasket between the pickup tubes and the block may be leaking
Third the timing cover or it’s gasket May not be sealing correctly.
Also, the dowel pins that position the heads on block are hollow and serve as oil returns I understand, if they were clogged or replaced with solid that can be a problem.  This was retold to me by a 1966 Caddy owner who suffered oil issues.
jerry 1261
Their is should not be a gasket on the block to pickup tube  I would take a close look at the pressure valve if stuck open would bypass oil pressure back into the  oil pump
With all due respects Jerry, there is a gasket that seals the pick up tube to the block.
Re reading the original post, I too would check to see that the pressure spring is not broken  or the valve stuck in the bore.
cadillactim
Is the gasket on between the pump plate and pump housing paper thin? When I rebuilt my 429 the gasket in the kit was too thick, which increased the clearance between the gears and the plate, which resulted in no oil pressure. Got another gasket which was paper thin and that fixed that.
Tim
Tim Groves
russ austin
Quote from: cadillactim on September 27, 2019, 06:08:54 PM
Tim
2 different parts are being discussed here. The oil pickup tube does require a gasket, and that part is in the oil pan.   The oil pump plate does also require a gasket, but it is critical that the correct gasket is used. It does se the clearance.  This end plate is on the oil pump which is on the front engine cover.
R.Austin
Again, as is often the case the OP has disappeared.
Big Fins
Yeah, it was fair to give him a month to at least respond.
Something may have happened in his life that we have no clue about.
But, that's the way of the world today for the most part.
I got mine...
I still like doing business the old skool way. A mans handshake or his word consummate the transaction. No matter what type of transaction it is.
Current:
Past and much missed:
1977 Brougham de Elegance
1972 Fleetwood Brougham
1971 Sedan de Ville
1970 de Ville Convertible
1969 Fleetwood Brougham
1969 Sedan de Ville
1959 Sedan deVille
QuoteI still like doing business the old skool way. A mans handshake or his word consummate the transaction. No matter what type of transaction it is.
John, that's only possible if the counter-party has gray or no hair.
2018 GMC Yukon
gkhashem
Well it would be nice to know if the problem was resolved so as to help others in the future, but as already said I got mine and I would add I cannot be bothered to give some feedback or a thanks.
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
jerry 1261
the gasket on the bottom of the oil pump   at the check valve is used as a gasket be is also a shim to set end play in pump very thin
R.Miller
Thank You Everyone,
Problem solved ! I talked to the Machinist that rebuilt the engine. He put the oil in the engine all 5 quarts through the oil sending unit opening using a pressure feed tank. I don't know why but as soon as I primed it through the Distributor it pumped to 30 lbs. in less than 5 seconds. No problems since . The engine Sat for 3 weeks after the dunk run before we got it in the car. But that should not have mattered at all. Somehow this had oil pressure on the dyno and zero in the car. The only part that we removed to install the engine was the water pump and of course the carburetor. I am wondering if all this had something to do with the way the gears in the pump are cut or meshed. Never even occurred to me anyone would fill an engine with oil like this , at least an old engine . Thanks for all the helpful suggestions .
savemy67
Hello Rance,
Being a natural born skeptic, I am curious to know how your machinist maintained oil pressure on the dyno.  Was the pressure tank fill device left in place?  In other words, was the pressure fill device responsible for the pressure on the dyno, with none being supplied by the engine oil pump?
As Yul Brynner said, "'tis a puzzlement"
Looking at the design of the oiling system in the 429, I suspect that the oil filter's anti drainback valve and or the bypass valve may have prevented the filter and or pump from being primed thoroughly because the direction of the oil flow was reversed by pressurizing the oil feed through the oil pressure sending unit opening.  If the pump had no prime, and or the filter had no oil, the engine start-up in the car would have happened with air in the pump and the filter, thus no oil pressure.
You can call me a doubting Thomas, but I like to be reasonably convinced of the engineering and science behind a process before being comfortable with it.  How hard can it be to pour 4 1/2 quarts of oil down the oil fill tube, and one pint of oil into the filter?
Respectfully submitted,
Christopher Winter
Christopher Winter
1967 Sedan DeVille hardtop
