1970 Coupe De Ville battery cable length ?
Started by Bill Balkie 24172, May 08, 2020, 08:16:48 PM
Bill Balkie 24172
Hello ,
     I am pretty sure the length of the positive cable is 65 inches . Is the Negative cable the same length ?
                  Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Definitely not.
The Negative Cable only has to travel from the Battery to the Chassis, or the Battery to the engine block.   Probably a distance of 12" to 18".
Bill Balkie 24172
Hello ,
      How about the positive being 65 inches does that sound about right ?
          Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Bob Hoffmann CLC#96
Bill,
I have a NOS neg. cable. Approx. 20". Spring ring. For sale if you want to be original.
Bob
Bill Balkie 24172
Hello Bob ,
     I have one spring ring myself , ( negative )   I am
Looking into another project . I
Might add a painless remote cut off switch to my car .   I think I have all the information I need . Positive cable is 65 inches hole to top post .  Thank you again for the trunk Mat Bob .
       Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
Quote from: Bill Balkie 24172 on May 08, 2020, 09:38:23 PM
Hello ,
      How about the positive being 65 inches does that sound about right ?     Bill
Not sure, but someone should come in here and give the Specifics.
But, it needs to be long enough to go from the Battery to the Starter Motor, without being too tight, or loose.   Nothing worse that being too close to the Exhaust Manifold, or rubbing on an upper control arm.
chrisntam
According to Rock Auto, it's either 51 inches or 58 inches.
Iffin it were me, I'd get the longer one.
Increase the cable size too, it will help with hot starting issues.
1970 Deville Convertible
Dallas, Texas
I’m looking for a repro set of spring ring cables for my 70
Eldo.
