Info: Inner Front Axle Seals-37 Fltwd
Started by Joseph P. McCormick, CXLC 14142, April 13, 2005, 09:31:32 PM
Hello, I need to replace the inner front axle seals, left and right wheels, on a 37 Caddy Fleetwood 75 series.  The old ones appear to be felt, but old, hard and leaking.  NAPA said that they do not have a listing for this part. I think the seals come in contact with the outer part of the inner wheel bearing which has the following part number of it: 909528.  Any help on where I could obtain these seals would be greatly appreciated.  Joe
Harry Scott (4195)
I replaced the seals on my 37 with the modern type, but cant find the number. If you give the old seal number and the measuremnts to Motion Industries, they are nationwide, (our local office # is 703-719-6803) they can match them up. Also, Olcar Bearings (advertises in Hemmings) probably has them. Good Luck
Joseph P. McCormick, CLC14142
Hello Harry Scott,
Thank you for your respond.  I emailed the Olson Gasket Company to see if they could supply the parts.  I was impressed with their website, as they offered felt gaskets.  Thanks again.  Joe
