HAS ANYONE USED LARES??
Started by JIM CLC # 15000, June 16, 2005, 05:50:34 PM
JIM CLC # 15000
06-16-05
All, I need to have the STEERING SECTOR re-built .(too much play in the steering).Has anyone used LARES CORP. a re-manufacture of steering gears. Any other co. would do.
Any help would be welcomed, any yeas or neys out there
Good Luck, Jim
Jack Carroll
Jim,
I had Lares rebuild the steering box for my
39 lasalle last winter and Im very happy
with their work. I beleave their turn around
time was about 6 weeks at that time. I had
mine sandblasted then epoxy primed it before
I shiped it.
Good Luck
Jack Carroll
JIM CLC # 15000
06-19-05
All, Iam considering having a new EXCENTRIC(sic) ADJUSTER made for the steering box for my 38 La Salle.( Instead of a new PITMAN GEAR/SHAFT. Does anyone have throughs on having that done? OR has anyone done that? Can the OFF-SET be made to shift the PITMAN GEAR more to reduce the PLAY in the box?
The problem I have with sending it to be rebuilt is its size.
The steering shaft does not come off of the steering box, consiquently, it would be a BIG box, about 8X8X5 or 6.
Good Luck, Jim
Jack Carroll
Jim,
I would just have the steering box rebuilt.I made a wood
box for mine and shipped it UPS with no problem. Lares did
not use my box for returning it. They use a heavy weight
cardboard box and foam in place the rebuilt unit for return
shipping. My box tought about 4 -5 weeks  from the time I shipped
it untill I got it back.
Im very happy with their work and should have had it rebuilt
sooner. I tryed adjusting the play out of it and it did help
soom what but it was still sloppy and leaked.
Good Luck
Jack Carroll
Paul Flykt CLC # 18899
They did a good job on my 57s steering box and pump. Id use them again. It took a little longer than 6 weeks even though I hand delivered and picked up.
