Valve Retainers
Started by Marc A. Thurston, September 21, 2005, 10:54:18 PM
Marc A. Thurston
Does anyone know where I might be able to locate a valve retainer for a 1932 V-8 engine?  I have tried Egge machine shop and they do not have any retainers.
thanks
Harry Scott (4195)
Marc, I need one too, for 1930 V-8, and havent been able to find one yet.
JIM CLC # 15000
09-22-05
Harry & MARC, since you said that you havent been able to find any (Harry said). Why not try to find a close match and take it to a machinist (take one that works for him to copy) and have it modified. I would start with either the Flat head Cadillacs or the straight-8 La Salle engine then other GM engines before trying other makes.
Good Luck, Jim
Harry Scott (4195)
My machinest has a coffee can full of them. Since I only need one (half) I guess Ill dump the can out and look for a match, or close match that can be modified. Interestingly, when the engine was disassembled there was only one half holding one of the values. Who knows how long it had been like that. Thanks.
JIM CLC # 15000
09-23-05
Harry, thanks for the reply and readn my post. My guess would be that the mach-a-nick that orignally worked on it didnt know that one-half had dropped-out.I would be for a close look-see in the Valve valley, usen a strong (bright) light.
Good Luck, Jim
Marc A Thurston
Jim - Thanks for the suggestion.  I will give this a shot.
Marc
JIM CLC # 15000
09-23-05
Marc, first, thanks for the reply. Marc, maybe you should contact Harry, as he said that his mach-a-nick had a coffee can full of odds valve retainers and that he would be looking for one that he needs. Maybe he can find two!
Good Luck, Jim
Harry Scott (4195)
Jim, I tried that. I also used a magnet and took the goop out and felt through it to no avail. Marc, I think the retainers are the same for both engines. I will try and get by the machine shop next week and check. How many do you need?
Marc A Thurston
Harry - I need one retainer.  Thanks for looking.
Marc
Harry Scott
I will try and get down to the shop before Hershey. Ill let you know.
